Wrecked car HELP!!
P.HUNT
15
SACRAMENTO CA
Ok so my friend wrecked his 1991 5.0 hit a pole.
it is a front end wreck and airbag was deployed.
I put in a new battery and everything works but it will not start, or even try to. I turn the key and absolutly nothing happens???
Is there something that needs to be reset??
I know about the inertia switch but that only controlls the fuel right?? It should still tyr to crank right??
Thanks Phil
yes inertia or however you spell it need to be reset. Anychance some wires have come off the starter? perhaps the impact made the clutch neutral saftey switch fall off the relay. perhaps the impact destroyed the starter relay.
The inertia switch only cuts power to the fuel pump. There are some other electrical issues going on. You can try to short the solenoid and eliminate the under dash wiring as a problem. If not check if the power is getting to the starter after that.
Kevin
