WTF is in my oil?
88 Fox GT
1,674
Iowa
So, I just noticed I had this yellowish gunk starting to build up inside my oil filler neck. What the hell is it? It couldn't be coolant could it? Doesn't coolant make the oil milky instead of chunky?
srothfuss said:
What kind of oil do you run?
How many miles?
How long have you been noticing build up?
What color is your oil?
(have you looked at the coolant yet?)
I just noticed it starting to build up. Engine has 130k on it. The oil is a mild-dark brown. The coolant looks normal.
I wonder if I somehow f'ed up my intake gasket and am now getting coolant in the oil. :damnit: :damnit:
Thats what water/coolant vapor mixed with older oil looks like.
Either you have some coolant in the oil or its sat for a long time and moisture collected in there. As it evaporates and rises to the highest point in the motor (underside of valve cover/filler neck), it mixes with oil vapor to produce...that.
Check oil color and coolant level. Run some seafoam through the motor just in case.
