  • 1994 - 1995 Specific Tech
WTF Son! AC compressor- how to move it?
  • Thread starter Thread starter 1994Vib.RedGT
  • Start date Start date Jul 11, 2006
1994Vib.RedGT
585
Denver, CO
Jul 11, 2006
  • Jul 11, 2006
How do you move this son of a ****** out of the way???? The damn chilton manual says nothing of this piece. please help
S/CBlack95GT
2,018
Tampa Palms, FL
Jul 11, 2006
  • Jul 11, 2006
I just unbolted the bracket and let the whole assembly rest on the oil filter.
braxx
22
  • Jul 11, 2006
Ford WSM:
Removal
1)Remove the drive belt. .
2)On the 5.0L engine, remove the battery and the battery tray.
3)Remove the A/C manifold and tube retaining bolt and remove the A/C manifold and tube (19D734) . Cap the refrigerant lines and compressor manifolds to prevent the entrance of dirt and moisture.
4)Disconnect the A/C clutch wires at the field coil connector.
5)Remove compressor retaining bolts.
6)Remove the FS-10 A/C compressor from the vehicle.
Install
1)A new service replacement FS-10 A/C compressor contains 295.7ml (10 oz) of the specified refrigerant oil. Prior to installing the replacement A/C compressor , drain four fluid ounces of refrigerant oil from the A/C compressor . This will maintain the total system oil charge within the specified limits.
2)Reverse Removal procedure(s). Tighten compressor retaining bolts to 20-30 Nm (14.8-22.1 lb-ft).
3)Using new O-ring seals lubricated with clean refrigerant oil, connect the A/C manifold and tube to the A/C compressor . Tighten each fitting to 17-23 Nm (12.5-17.0 lb-ft).
4)Connect the A/C clutch wires to the A/C compressor clutch field coil connector.
5)Install the drive belt .
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
A
Strange AC issue
  • Adanesahde
  • May 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 3, 2025
Mcmahst
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
