Wtf still no spark
As you have already found out, throwing parts at an unknown problem is an expensive & ineffective way to fix a problem. Time to do some thinking about how things work.
Get out your test lamp or voltmeter. You may have some wiring problems. Make sure that you have 12 volts at the coil & computer.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 21-June-2006 to include 94-95 specific information
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the Upper RH corner to ground.
attachment.php
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) 86-93 models only: Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay. The fuse links live in the wiring harness near the starter solenoid.
F.) Fuel pressure regulator failed. Remove the vacuum line from the regulator and inspect for fuel escaping while the pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
Ok so i did your checklist and i have 12 volts all around the board.. except the coil i have 12 v going into the computer and at the eec relay and all the fuselinks check fine.. So does this mean that my computer is done for?
You should have 12v ignition to the coil. That wire goes through a 20ga fuisable link, the clutch switch, and the neutral safety switch before giving power to the coil.
If you have an automatic car, the clutch switch has a jumper plug installed, if you have a manual car the neutral safety switch has a jumper plug installed. See that whichever one you have is actually there and snug.
Start with the pedals first, if you don't have any power incoming to the clutch pedal (or plug) than find that fusable link andc check it. The wire is Red with a light Green stripe. If you do have power incoming to the clutch and power outbound from the clutch when the clutch is pressed in, or when the plug is installed, then check under the car on the driver's side by the transmission. Same deal, you should have power on both sides when the plug is installed/transmission is in neutral or park, if you do then you should have power at the coil, if not, check for a broken wire between there and the coil.
No 12 volts to the coil is either a bad ignition switch or bad fuse link. Look for 12 volts at
fuse #18 on the fuse panel. No 12 volts here and the ignition switch or wiring connecting
to the ignition switch is bad. Look for the blue fuse link in the red/green wire on the
diagram: if you have 12 volts at fuse #18 and no 12 volts at the coil, the fuse link is bad.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
:stupid: :) It will flash fast, but you will beable to tell it is flashing. Remember.. you're looking for a pulsating GROUND (which is the trigger from the pick up for the coil to fire) so hook your test light to power, and check ground for pulsation. :nice:
To add a little: the ground trigger comes from the TFI itself (if it was from the PIP, we'd have no advance/computer input regarding timing).
I say this not to be anal but in case the ground pulse is an issue, it might help with backtracking.
Good luck.
Ground wire going to the coil. Hook your test light to positive, and back probe the negative going to the coil. Have a friend/family member crank the car. Watch for pulsating ground (test light blinking fast). If it blinks, you have signal going to the coil. Meaning it should fire. If you have no output from the coil, then it's bad. Chances are you have no pulsating ground.
So tried every thing possible even wigling wires and what not.. Then we went to buy a better test light to check for the pulsating ground it started right the hell up... Any ideas?
