WTF?
  • Thread starter Thread starter Modular2v
  • Start date Start date Mar 9, 2009
Modular2v
3,222
23
99
oklahoma
Mar 9, 2009
  • Mar 9, 2009
Took the car out to the track with some bfg drag radials and got a disappointing ET and mph! I know the 60ft is trash but i was expecting a little better!
Mods are in my sig and this is what the slip reads.
RT: .498
60ft: 2.007 (horrible i know, but this was my first time to race with drag radials, most of the time i use slicks)
330ft: 5.674
1/8th: 8.645@82.91
1000ft: 11.191
1/4: 13.315@106.49
I only got to make 1 pass. It was humid and warm. I also added subframe connectors. Im thinking the car needs a tune pretty badly????
Modular2v
3,222
23
99
oklahoma
Mar 9, 2009
  • Mar 9, 2009
just now noticed this but, does anyone else think it is weird that the difference between the 1000ft mark and the 1/4 is 2.124 seconds?
KamiKaziDK
555
Mesa, Az
Mar 9, 2009
  • Mar 9, 2009
When my 95 only had exhaust and my tranny was starting to go out on me I ran
R/T: .074
60': 2.276
330: 6.570
1/8: 9.956
MPH: 72.83
1000: 12.832
1/4: 15.267
MPH: 93.37
So that's only a difference of 2.435. Perfectly normal man. Did you have wheel spin at any of your shifts or on launch? You should be into the 12s with a good launch. Also, how hot was the car when you made your run? If it's really humid your car wouldn't like that either. Have you spent much time at the track? experience is a biggy. The car might need a little tuning, but you sound like you're doing fine. making only 1 run makes it hard to see if you need practice or if it's the car too, but with a 13.3 on one run
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Mar 9, 2009
  • Mar 9, 2009
Your mph is pretty healthy for a low 13 second pass...i was going 107 with a 12.8. The 60 isn't great so get that down a couple tenths. How well can you drive? What did you launch at, what do you shift at? Is your mod list totally complete (as in, do you have headers, short belt, pulleys etc). I would think that with your heads and cam you should be as quick as my car was...but then i drive mine without mercy..lol.
.:Slo5oH:.
  • Mar 9, 2009
The 60' times are definitely weak, either spinning a lot or bogging. It takes practice and effort to get the short times right.
I personally tried several different air pressures in my MT drag radials, different burnout types (waterbox and bake them, dry hops...no water)..
In the end I have a best of 1.5 60' and 7.87 @ 96 mph in the 1/8th.
There may be a big disadvantage for you in Oklahoma based on sea level, what elevation is your track? The mods you have listed should produce lower e.t.'s. Keep practicing, figure out how high RPM's you can launch at without spinning (if your suspension and torque boxes are done.... mine are welded and I have installed rear upper/lower CA's)
Modular2v
3,222
23
99
oklahoma
Mar 10, 2009
  • Mar 10, 2009
I have plenty of experience driving...just not on drag radials. Here is the last car that i built YouTube - Foxy331 BvsF07 and YouTube - my 10.95@125
Only reason i sold that car is because i wanted to try something different (street car setup) I plan on a turbo in the future but im thinking this turd should be deep into the mid 12s ATLEAST with the mods it has!
Modular2v
3,222
23
99
oklahoma
Mar 10, 2009
  • Mar 10, 2009
as you can tell, the above passes were done B4 i switched to the c4
Cobra_Dusten
246
Marysville, Wa
Mar 10, 2009
  • Mar 10, 2009
i dont see that combo going deep into the 12's. I see it running 12.7's maybe with some traction. if you can get that sixty down even to a 1.8X you are looking at 12's with no other changes. maybe with some better air, and a better hook, it'll run better.
Cobra_Dusten
246
Marysville, Wa
Mar 10, 2009
  • Mar 10, 2009
im assuming you havent listed your exhaust mods? If you are still running through a stock H-pipe and stock manifolds with that combo, you are choking the life out of it
Modular2v
3,222
23
99
oklahoma
Mar 10, 2009
#10
  • Mar 10, 2009
  • #10
BBK equal lengths with o/r h pipe. I also have a some longtubes with matching h pipe sitting in the shop i have been thinking about putting on. I dont see how this combo doesnt run mid 12s honestly.....i have seen people run 12.1xs with less
I also find it a little pathetic that my 03gt almost ran the same time with just gears, exhaust and sticky tires!
.:Slo5oH:.
#11
  • Mar 10, 2009
  • #11
Sorry if it came across like I was saying you didn't know how to drive.... I was trying to say that there is a learning curve going to DR's but really, all it takes is seat time with them to get it dialed in.
I run mine at around 12-14 pounds and do a decent burnout... but, my track is at or below sea level. Also, the track I go to is 1/8th mile so I'm probably not qualified to give advice on what the top end is looking like.
What RPM are you crossing the timing beams at?
Modular2v
3,222
23
99
oklahoma
Mar 10, 2009
#12
  • Mar 10, 2009
  • #12
No problem man, i knew you were not being a smart ass! Im crossing the traps at around 5200 in 4th if im not mistaken
.:Slo5oH:.
#13
  • Mar 10, 2009
  • #13
I don't know where the issue is, but the combo should deliver better times. I'm not seeing mid or low 12's like Cobra Dusten said... Either way, keep going and changing things... good luck.
How opposed to a small nitrous shot? Woke my car up for sure.
Cobra912
1,777
11
39
Wish I was anywhere but here
Mar 10, 2009
#14
  • Mar 10, 2009
  • #14
holy crap on the first video pass the front wheels lifted on the first shift - sick!
Modular2v
3,222
23
99
oklahoma
Mar 10, 2009
#15
  • Mar 10, 2009
  • #15
LOL already have a NX kit hooked up, just have to fill the bottle I was making sure the car was running the way it was suppose to all motor b4 i hose it oh well....11s will be in reach with the flip of a switch!
Modular2v
3,222
23
99
oklahoma
Mar 10, 2009
#16
  • Mar 10, 2009
  • #16
LOL you saw that? 2nd gear wheelie FTW I miss that car Thought you would like to know that was a 331 stroker
.:Slo5oH:.
#17
  • Mar 10, 2009
  • #17
I heart nitrous.
Nice vids too.
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
V
Track Numbers ... Not Thrilled!
  • vpap1
  • Jun 21, 2012
Fox 5.0 Mustang Tech Jun 22, 2012
vpap1
V
  • Locked
Just Some Suggestion's For Foxes
  • Detroiit
  • Jul 24, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2014
Street Legends Domestic Vs Imports Track Event And Car Show Friday June 8th
  • bizspeed
  • May 31, 2012
  • Regional Forums and Event Information
Regional Forums and Event Information May 31, 2012
bizspeed
