wth. my bassani reply
I candy
597
Honolulu
Sheldon Dzodin said:
Bassani tips are stainless steel and will not rust. If there is some corosion, that can be cleaned up with stainless steel polish, It is non abrasive.
Sheldon Dzodin
Bassani Xhaust
Tech Support
1-866-782-3283
this is what i got after telling them that i had the car in storage not running. and discovered some rust on the tips. i asked what they recomend to remove the rust.
ideas, thoguhts or opinions?
ok thanks guys. i was always under the impression that stainless can rust. its just very hard for it to happen. but since there is still steel in it it would be possible.
i'll go home and check it out.
Typically stainless steel will not rust unless it becomes contaminated.
Just do not use those Brillo or s.o.s pads, or abrasive "lubes." That can be a factor that can cause contamination.
Also, not all stainless steel is created equal.
my bassani tips get little rust spots comes rite off with ------>
image.php
