1994 Cobra with AFR heads and MM suspension
Killercanary
The car that set the bar.
Altoona, PA
I'm selling my '94 Cobra. I bought this car in January 2009 from the original owner. He was a dentist and kept the car 100% stock and had it serviced at a ford garage. He ordered the car in late '93. It is Rio Red with black cloth interior and has ~158K miles on it. I have modified it since taking ownership and replaced a lot of parts. I'm in no hurry to sell but I have made up my mind that I want something newer to play with. The car is not a show car and it has scratches and dents, a few minor rust spots, but all in all the paint is what I would consider good for being 17yrs old. Since this car has modifications that some may not want I am willing to sell the car with or without some of the parts that are currently installed. The car has over $3500 in suspension parts alone, but they definitely sacrifice ride quality for handling. See the options below for details on how I am offering the car for sale.
OPTION 1
Car as it sits with the modifications listed below: $7250 OBO
Engine
-AFR 165 60cc heads with titanium retainers, VTO seals, and LS1 style springs
-65mm FMS throttle body
-lunati multi-index double roller timing chain
-1-5/8” FMS shorty stainless steel headers
-2.5” Bassani stainless steel offroad X pipe
-2.5” cat back with magnaflow mufflers and 3” tips
-newer 24lb injectors
-Mallory adjustable fuel pressure regulator
-255lph Walbro fuel pump
-aluminum under-drive pulleys
Front Suspension:
-2003 Cobra A arms with low friction ball joints
-Koni sport SA “yellow” struts
-MM coil-over kit with 425lb springs
-MM 4 bolt caster camber plates
-energy suspension sway bar mounts
-steering rack limiters
Rear Suspension:
-MM heavy duty torque arm
-MM panhard bar
-MM adjustable rear sway bar
-MM road race lower control arms
-MM/Bilstein shocks with 325lb coil-overs
Chassis:
-MM full length subframe connectors
-Carbon fiber clutch packs in stock differential
-BBK strut tower brace
-tubular “offroad” front bumper
-battery relocated to trunk
-new axles bearings and seals
-Pro 5.0 shifter
-urethane motor mounts
-urethane transmission mount
Misc.
-stock cobra intake ported to match heads
-3.08 gears
-replaced fuel fill tube
-replaced fuel tank seal
-replaced water pump
-previous owner replaced clutch prior to me purchasing
OPTION 2
Car with the removal of the suspension modifications but with what is listed below. This option may require a non-refundable deposit before I start removing anything from the car:
$6000 OBOwith '03 Cobra wheels
$5700 OBOwith stock 94 cobra wheels
Engine
-under-drive pulleys
-180* thermostat
-all new gaskets
Front Suspension:
-stock A arms
-stock springs and struts
Rear Suspension:
-stock
Chassis:
-Pro 5.0 shifter
-3" wheel studs on all 4 corners
Misc.
-3.08 gears
Additional items available for additional purchase:
-17x9 anniversary cobra wheels
-tubular lightweight chrome moly front bumper
-factory 5 upper and lower rear control arms with urethane bushings
-'03 cobra A arms
Pictures:
Stock wheels:
Please email me for more details at KILLERCANARY AT HOTMAIL.COM. As stated all prices are OBO and I'm willing to get creative with adding/removing parts to get the price to a point we can both be comfortable with if need be.
