  • SN95 4.6L Mustang Tech
X engine code?
  • Thread starter Thread starter gotchopsticks
  • Start date Start date Jan 2, 2006
G
gotchopsticks
315
  • Jan 2, 2006
i have an 02 gt, and i was looking for a valve cover gasket, then some prompt came up about different engine code. it seems that the X engine code means Windsor, or something along those lines. but what is different about an x engine code, a W, or a 9? thanks
Outlaw97GT
234
Redneckville, Tx
Jan 2, 2006
  • Jan 2, 2006
X= Romeo
W= Windsor
G
gotchopsticks
315
  • Jan 2, 2006
Outlaw97GT said:
X= Romeo
W= Windsor
what are the differences between those engines?
Outlaw97GT
234
Redneckville, Tx
Jan 2, 2006
  • Jan 2, 2006
Check these links out....
http://www.babcox.com/editorial/ar/eb40228.htm
http://www.musclemustangfastfords.com/tech/0302MMFF_MixMatch/
Hope this helps..
sgarlic
3,085
Jan 2, 2006
  • Jan 2, 2006
Great post. Those links are 2 of the best.
G
gotchopsticks
315
  • Jan 2, 2006
thanks, but that didnt really help me much, i have an 02, and it hardly said anything about my motor. unless everything from the 99+ applies to my motor, im still in the same position. at the end of the second article it stated that late 2001 to present had different water pump design, so could that mean that other parts are different as well? i was hoping that the different engine code would tell me why i beat another 02 gt with the same mods as me by at least a second, multiple times. thanks again
sgarlic
3,085
Jan 3, 2006
  • Jan 3, 2006
Perhaps asking that question to begin with would've helped. You have a romeo block, and the only notable change through the years 99-04 was the water pump pulley change, and the oil plug in the oil filter housing. The reason the windsor block was used at one point was because of a fire in the Romeo plant.
You beat the other car with the same mods because 2 equal cars racing is a drivers race (better driver wins.)
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
