  • SN95 4.6L Mustang Tech
Xcal 2 problem
  • Thread starter Thread starter Mattstang04
  • Start date Start date May 25, 2008
Mattstang04
1,152
144
104
St. Louis, MO
May 25, 2008
  • May 25, 2008
Ive had my xcal2 for quite a while but really only used it for my axle ratio change. I wanted to reset my rev limiter to a lower setting and realized that without my stock settings I have no limiter. Has anyone else had this problem? With the stock settings everything is fine, it hits the stock limit at 6000 rpm. As soon as I change to the performance tune and adjust my perameters, no rev limiter at all. The speedo change works, my reset idle speed works, as well as timing tweeks, but it voids the freakin rev limiter in drive and idle. Thanks ahead of time.:SNSign:
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
May 25, 2008
  • May 25, 2008
Not sure if they are the same but i know with my old predator i could go in and modify the performance tune.
Mattstang04
1,152
144
104
St. Louis, MO
May 25, 2008
  • May 25, 2008
I can change the parameters but as long as the performance tune is installed, no matter what rpm I set the rev limiter to, it just doesnt work. Take the tune out and the stock limiter works fine. I dont understand, could it be a programability issue with my ecm?
Tim2002GT
635
Tulsa, Oklahoma
May 25, 2008
  • May 25, 2008
Maybe there is a problem with your end user rights to that tune. I would contact whoever you got the tune from and have them email it back to you with the correct rpm you want for the rev limiter.
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
O
injectors keeping up?
  • optionizerSS
  • Apr 4, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 4, 2025
optionizerSS
O
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
