K Kenney07 New Member Apr 15, 2007 12 0 0 CT Jul 3, 2007 #1 Jul 3, 2007 #1 hey guys... I recently installed an xenon headlight and foglight kit into my 98 gt. Im now getting radio static when the headlights and foglights are on. Any ideas?
screamin gt 5 Year Member Apr 9, 2007 393 6 28 central CT Jul 4, 2007 #2 Jul 4, 2007 #2 try putting your old bulbs back and see if it goes away I once had a car that had static from the radio that whistled my exhaust note. annoying
S san~man O-G Founding Member Nov 29, 1999 8,546 3 78 A little grass shack on a big lava rock Jul 4, 2007 #3 Jul 4, 2007 #3 Check your ground for the HID harness.
EDGE Motorsport Member Sep 24, 2004 561 2 19 Saleen S281, London, UK Jul 4, 2007 #4 Jul 4, 2007 #4 san~man said: Check your ground for the HID harness. Click to expand... there was a big discussion about this on another forum a while ago, most peoples issues were solved by re grounding the balast packs
K Kenney07 New Member Apr 15, 2007 12 0 0 CT Jul 4, 2007 #5 Jul 4, 2007 #5 Where do you recommend grounding the balast to?
S san~man O-G Founding Member Nov 29, 1999 8,546 3 78 A little grass shack on a big lava rock Jul 4, 2007 #6 Jul 4, 2007 #6 I don't believe the ballast itself has a ground, but the harness does/should. The harness ground should go directly to the negative of the battery.
