yet another "combo" question...
oosmytoo
530
Portland - Oregon
I will be putting the following combo in my car by the end of next month just wanted to get some of your guys opinions before i do so.
Trickflow street heat kit
DSS Pro bullet 331
FRPP 65mm TB
C&L 76mm MAF w/inlet pipe
FRPP 30# injectors
Kirban AFPR
28oz balancer and flywheel
255lph fuel pump
FRPP roller lifters
March underdrive pulleys
PMS tuner
is there anything i should do differently? also planning on getting a PTK here soon, thats why i chose the C&l because it can easily be recalibrated.
im guessing i must have a pretty descent setup? being that none of my fellow stangers replied! :shrug: :D its all good, mainly what im concerned about is.. will the 30# injectors be too big for now? and should the 76mm MAF be large enough? :shrug:
Sounds like a good setup, especially with the PTK in the mix.
Some might tell you to get a bigger MAF and T.B. But if you are definitely going to boost your combo, it shouldn't matter as much. If you already have the MAF and T.B., I would stick with them.
