And just like that, a couple clicks, and it's headed to my house. Paypal is the debbil.http://www.summitracing.com/parts/pio-pe-108-b
This also covers oil galley plugs. They are probably missing too.
I understand the logic and need to do so if this were a high $$$ race engine, but this is a junk-yard slug with a blue plate special overhaul. If it lives more than 6 months before I kill it, then it will be a wild success. There are far too many variables to spend much money on it now. I have a good crank and forged pistons on the shelf once it gives up the ghost. Those will get a full service at the machine shop.
You have a really wussy cam.
Best news I've had all day!
I haven't had enough coFfee to even begin figUring out how to respond to that.You have a really wussy cam.
Stop bein such a goober.
Be a man, Get somethin with 650 lift, and about 260 degrees actual duration at .050.
Then think of all the youth envy you'll foster the next time you come lopin' into your local Pop shop.
Uhhhhh,........ That Collin is sooo Btchin.
Broken springs, bent pushrods, premature rocker arm failure, and pss poor street performance is only a phone call away.
Even the Monster has a mechanical roller cam,....time to step up.
UrMom
I thought it was quite witty for a Monday morning.You'll think of something.
I guess this is a bad time to mention I ordered flat tappet lifters instead of hyd rollers. So much for me relishing the quick wit.The Capital letters helped alot.
So...Your push rods are going to be too short. Better order new ones.
*sip*
So...
I've never actually had to measure push rods before. I ensured the cam was on the base circle, installed a 'fixed' lifter and the measuring tool, and installed the pedestal lifter. Then, I extended the rod until zero lash.
Sound right?
The cam in the Monster is that big.552/563, 228/232 and 114-degree LSA. It's no B cam, but it should work well enough.
