The main difference from the V6 to the V8 axle back should be the sizing of the exhaust tubing. As far as Magnaflow goes for example, the V6 kit uses 2 1/2" tubing while the V8 kit uses 3" tubing. This may or may not be interchangable but frankly it's your dollars to spend and find out. Worst case a little welding would be required and at that point are you even saving money? Muffler for Muffler the car will not sound like a V8 simply because you installed a muffler that was once on one
How an exhaust system sounds is very subjective, what sounds good to me may make your ears bleed or vice versa. Personally I've always enjoyed offerings from Magnaflow. If you check out AmericanMuscle, CJ Pony Parts or LateModelRestoration websites you should be able to hear countless numbers of sound clips for the exact mufflers you are looking at designed to bolt up to your car. Stick to a bolt on axle back kit and do this yourself in the driveway IMHOWould it be better to get a muffler shop to do it? I just want a little bit better sound without being rice-ey and get a little power. Would flowmasters sound good on it?
For that matter, a lot of the site vendors (mentioned above) offer discounts specific to member here at Stangnet. If you need help getting ahold of someone for a discount code just hollar
MBRP is good stuff too, I have used their exhaust on a countless number of trucks and never had any issues. I actually have MBRP's cat back on my 2011 F250 DieselOk. I like the American muscle ones but $400 is a lot to spend on just axle back kit. They have a mbrp kit that's decent on price. Is that a good brand?
