Yes, only difference is my jumper was purple
91-92 uses a blue jumper
88-90 used the purple jumper.
At least that narrows down the year o2 harness you had.
The jumper connects the blue/yellow wire to a purple/yellow wire.
If I would jumper it the 89-90 way, it would be like a creamy pink/ purple to purple/yellow
I think that wire is supposed to be white/purple.
In that case, everything you have here is correct in a mass air application. In an automatic application, the Purple/yellow wire would loop to the White/purple wire. In a 5-spd setup, the purple/yellow loops to the blue/yellow.
I believe the scenario that fries the ECM is when the Blue/yellow and White/purple get looped together. I think this might be what you had before? Perhaps you want to open up both ECM's and inspect that trace.
If you can solder, it can be repaired.
659631
I'll open them up tonight and look at the traces. Would a burnt trace cause the 67 tho?
Unsure at this point.
Quick way to check if the trace is burned without opening up the ECU. Pin 46 is wired to Pin 40 and pin 60 internally. Remove the ECU and touch a multimeter set on resistance between 46&40 and then 46&60. It should be less than 1.5 ohms of resistance
I'm actually an Mech. Engineer, not EE. Electrical was really a side gig for me.
Yes, because the trace that is burnt, is what is used to let the ecm know if it's in gear or not. Basically when the trans is in neutral or clutch is down, pin 30 at the ecm gets grounded to pin 46. If the trace is burnt, pin 30 can't go to ground. So code 67 and a bunch of other codes get logged. Is code 67 the only code you got?
You have to the computer out, go ahead check the continuity from PIN 30 to the blue/ yellow wire at the clutch switch.
