does the S197 Mustang have the so-called 'Black Box' that records telemetry data?
If so, where is it located? what are the parameters?
shooterm1 said:does the S197 Mustang have the so-called 'Black Box' that records telemetry data?
svttech76 said:The only time that live data will be recorded is to take a snap shot of telemetry or live data to aid in driveability and emmisions repairs. We can setup a black box to use for diagnostics and send it with the customer but that is a add on device.
The Fang said:The "Handbook" does not state any info on the EDR so I assume (I tell my kids not to assume) there is not one on the S197.![]()
) are using the terminology "Event Data Recorder" as a blanket generalized term for what is in the vehicle.
) to chime in here and an confirm or deny my understanding of this unit, but my limited understanding of the RCM is that it holds a 30 second snap shot of the cyclical data events and input it receives from the various sensors and system equipment. So, recycling of the data occurs every 30 to 60 seconds as it monitors and logs the input data for probable use in the event of an incident it warrants as being severe enough to activate the SRS.
srothfuss said:First, it's not a dirt bike. It is a privilege to drive a car, not a right
Second the device is only there to record data when you are involved in an accident. If you don't do "stupid" things on the road, there is nothing to worry about.
A few years ago a Mustang GT crashed on I-696. Some Kid was traveling at 100+ MPH and lost control of his car. It slammed into a overpass and he did not survive. Had he been doing the speedlimit his chances for survival would have greatly increased because he probably would have lost control of his car.
SVTdriver said:While I would probably prefer it not to be in my car. I undestand the reasoning behind it. And realize if I do something stupid enough to warrant using the data. I deserve to have it used against me.
/threadSchlitz-420 said:Albeit a car is not a dirtbike (although my streetbike does not have one either), and it is a priveledge to own firearms as well, they do not test fire my guns when i buy them so they can trace the rounds in the event i use the weapon.
+1I think maryland did or still does ballistic fingerprinting, it doesn't prove too effective since it's ridiculously easy to change a ballistic fingerprint in a firearm, Similar firearms have similar fingerprints, and their a lot of firearms sold in other states, or transfered by private sales. Waste of money. These things that make it ineffective aren't things that make a black box in a mustang ineffective though. It worries me. I would have to be going 10 over on the interstate with no one else there and accidentally wreck the car, then get in trouble for something that minor b/c my car told on me.
I am not sure if "they" (being the all knowing omnipotent Gods of the News world) are using the terminology "Event Data Recorder" as a blanket generalized term for what is in the vehicle.
We will want Mike (CALLING SVTTECH76) to chime in here and an confirm or deny my understanding of this unit, but my limited understanding of the RCM is that it holds a 30 second snap shot of the cyclical data events and input it receives from the various sensors and system equipment. So, recycling of the data occurs every 30 to 60 seconds as it monitors and logs the input data for probable use in the event of an incident it warrants as being severe enough to activate the SRS.
It is not a "recorder" per se, as much as an input snap shot of the data the RCM uses to activate and deploy the system. It is retained for a short-duration cyclical period of time until it cycles again.
The information can be retrieved with a SRS Diagnostic tool and Yes, this information can be used in criminal and tort proceedings if obtained under the appropriate guidelines of Judicial Administrative Law.
2006 ford mustang service manual said:The RCM is mounted on the center tunnel under the instrument panel. The RCM:
deploys the air bags in the event of a deployable impact.
activates the safety belt retractor pretensioners to remove slack from the safety belt webbing.
monitors the SRS for faults.
illuminates the air bag warning indicator if a fault is detected.
illuminates the PAD indicator when conditions warrant illumination.
flashes the air bag warning indicator to indicate the lamp fault code (LFC) detected.
communicates through the data link connector (DLC) the current or historical DTCs.
signals the instrument cluster module to activate a chime if the air bag warning indicator is not available and another SRS fault exists.
records deployable and non-deployable impact data.
