Basic Smog Pump question.. with a twist.
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Alright, as a long time member of the board I have searched this topic over and over and really never got extremly cut answers... plus this has a little twist so Im gonna go ahead and ask.
To start, Im currently building a mexican 331 stroker for the stang. So, since the engine I currently have is basically getting the boot and I will have an empty engine bay during the swap I've been kicking around the idea of deleting the smog pump while im at it for the weight savings and even more sore for athestetics.
A) I've heard of potential proplems with the smog pump removal dealing with a/f ratios because the o2's arent getting a correct reading... this true or am I off here???
B) I live in Indiana (no emmision testing) so of course I have an O/R h-pipe (no cats)... is there anything else the removale of the smog pump is going to effect badly?
C) or what I like to call.. the *twist* The stang currently has an SC-Trim Vortech blower and will be switched over the new powerplant when the time comes. (prolly getting the trade in upgrade to S-trim since I can afford it and will probably need it) Anyways, the blower required moving a lot of the accessories around using its own bracket. This has got me thinking. Is it still possible to run the smog pump delete kit pulley with the vortech bracket? Is it still possible to run the belt without a smog pump pulley and not interfer with anything since the other accessories are moved and not exactly like a stock setup???
Im sure answering #C is gonna be tough, but I would like some answers if anyone has got them.
Thank you.
Not emissions testing, no cats, no smog pump, no reason to keep any of the parts. The O2 sensors should't have any problems dealing with the new setup. Just remember that if emissions testing comes to where you live, or you move to where it lives, you will need the smog pump & cats to pass the test. That also means that you probably can't legally sell the car to someone who lives in an emissions testing area.
When you take the car to get the dyno tune required by the supercharger, have them program out the smog pump system. That way you won't get any codes because of the missing equipment.
It shouldn't be a problem at all. My 347's a/f is fine w/o the smog stuff, with off road exhaust and nitrous.
Also my pals car was too. He runs a charger. He uses the smog delete with his Paxton. The paxton kit relocated a thing or 2 as well.
any idea what brand delete kit he used? and if there are any pics??? :shrug:
He has the Auto Specialties from Summit. I have the UPR one. They both look identical. I don't have any pics of his. I do know that its all on the passenger side. The alternator was moved to kinda between the crank pulley and smog pump and it hangs a little lower than the smog pump. The engine is out of the car now waiting on his new stroker. So taking a quick snap of it is out of the question.
you can delete the smog pump and run a short belt with no problems. i dont know about the SC setup if that what u guys were talking about.
u have the change the belt routing a bit.
just remember the WP pulleys stays on the outside of the belt.
I love living where there is no emissions
thanks for the input there Roland... (cough.. post whore.. cough cough) :rlaugh:
Just to clarify.. yes its a supercharged application in which things have been moved around. So far I've seen a *You need the elminator kit* and a *you dont*.
Anyone wanna +1 either of the statements? :shrug:
I guess I can always just play it safe and get the kit either way..
