"Streetable" = driving in traffic with no safety issues?
We need to define what "streetable" means - I always thought it was, very simply, "can you drive this thing in traffic and not have it stall, get away from you with unpredictable bursts of power, have enough vacuum to run power brakes if need be, not overheat in stop and go traffic, etc." A manual trans just exacerbates any rough running condition, and flywheel plays a big part too.
To my limited knowledge, of course engine choice, intake and carb, cam, flywheel choice, trans choice, rear gear choice, as well as clutch type if used with a manual, fan type, and accessories on the engine, all these make a difference. And this is just to define STRICTLY if it can be used in stop and go traffic with no issues. Not even talking about reliability or "daily driver" questions yet.
I can tell you this so far - taking a 35 year old 100k 302-2v that only has rebuilt heads and putting on an AL flywheel, 5-speed OD tranny, and opening up the restrictive exhaust to a 2.5" Magnaflow kit and keeping 2.79 original gears will yield you . . . a car that sometimes takes double-clutching to start up (AL flywheel), runs a little rough and burbles on decel (too much exhaust, not enough intake), and either wants to GO or stop. (AL flywheel and big exhaust play a big part here) My car is happiest at WOT starting at about 15mph.
And boy does it sound great at WOT when it starts to rev. I am probably gonna kill that little 302.
I probably have the 150-hp turd, as polished as it can be.
I'm in the "solid foundation" camp - did brakes, tranny, subframes, suspension first (look at .sig) and I will do the rear end before the engine goes in. 408 stroker that will be as "streetable" as possible in the 400-500hp range with a 9 compression or so so that if I go crazy and supercharge it, I can.
