lookie what i did!!!
mustangt562
226
Long Beach
well my latest project is finished. a snow performance boost cooler NA and a MSD 6860 timing advance box. Let me tell you the boost cooler is awesome. I was on the freeway and dialed the timing up by 10 and floored it. of course it started pinging so i hit the meth injection switch and the pinging stopped and the car just launched!!! Then I was at a dead stop dialed the timing up to 5 and pushed the gas pedal by about a third and the tires did not stop squeeling untill I let off the pedal AND I HAVE AN AODE!!!!!! Best 2 mods ever (not counting the chp 347 street fighter pro street :) )
So are you running it N/A? Also, those spark plug wires a HUGE. I've been thinking of a system like this since I'll be running 10.4:1 comp on pump gas and alittle worried about pinging. Seems like $300 is a good deal on their site.
you wont be sorry. it allows you to get way more out of your engine. keeps the combustion chambers clean too. meth can lower your intake temps by 60-100*. I think that everyone is so stuck on nitrous and such and just plane ole school meth injection gets overlooked.
how does it work on a n/a setup??? this is interesting...would it be worth it on a h/c/i 5.0?
well it works on intake vacume but I have it bypassing the vacume switch and activated by a switch in the cockpit. So when I open it up I can turn on the spray and turn it off at will. On a n/a H/C/I setup it will cool your intake charge by 60-100* which is always good for HP and it will allow you to run crazy advanced timing which will increase hp too. also it keeps your combustion chamber clean which prevents 'hot spots'. its actually a pretty pimp kit for 300 bucks.
I'll be running a H/C/I next summer with a 100 shot of dry nitrous. Would that help me any and would it be safe to use with nitrous?
Also, what is it actually spraying into the engine? is it true that it's just winshield washer fluid?
