spark plug?
873Stang
221
riverside
what plug would give the 302 most performance??? i have motorcraft gaped at .45! I heard somewhere that if you gap the at .50 car would run little ruff at idle but if you step on it the it hauls is this true?
either gap will be fine... actually .054 is the stock gap. As majority will tell you the best and most popular plug is the autolite, not only the most common for the 302 but exceptionally affordable and effective.
If they're plain copper plugs and they're new, you can just pull them and regap them if you desire. Motorcraft is every bit as good as Autolite (scuttlebutt has said they are the same plug, but I've never definitively found out if that's true).
Good luck.
