Rear Window Defroster Help
WldstrawbryLX
35
Everett,WA
So for I've checked all fuses and relays associated with defroster...that I've found. When I push the button on the dash, the little light comes on....I here a click, but the rear window doesn't defrost. Is there another relay somewhere that Im missing?? (AND) Should there be voltage present at the leads that attach to the window itself?? TIA.
Saleen is right-on. Also look for a broken line in the back window. They used to sell conductive paint to repair the lines (used in Alaska, where the defroster was real necessary) but I'm not sure if they still sell the stuff.
Good luck.
Is the rear window tinted? If it is theres a chance one of the lines have been "cut" druing the tint install.When i had my windows tinted the guy fooked up my rear defroster.It was a pain to find the bad spot but after a lil conductive paint it works fine now.Good luck.
First post. Just wanted to ask about rear-window defroster repair.
I've got an 89 LX hatchback and the defroster is missing a couple of "lines" on the grid.
Any good source or suggestions as to how to repair this? I can solder, etc. and have multimeters and tools.
Thanks!
Hey,
I have the same problem with my car, only 2 strips work. Teh rear window has tint on it. Is it possible to use the conductive paint without removing the tint? I don't really want to have to pull off the tint, but i can't see ***** out the back in the mornings.
Sorry but the grids are under the tint. To try to do any repairs, the tint will have to come off. I remember my installer saying something about a special process using a garbage bag and heat to remove the tint since there is a rear defroster. Don't quote me on how its done, but it is different than just scraping it off. Scraping it off will take off your grid too, which is not what you are wanting to do at all.
I was easily able to find the gaps of my grid with a multimeter. I then set my meter to read current and jumped across the gaps. This confirms that the rest of the grid line is good. *FYI - there is about 1 Amp of current going through each grid line. * So, with about 14 grid lines you are drawing 14 Amps to run the defroster.
Now - how did any of you clean off the insulation covering the grid lines? I tried a few things, but nothing with great results.
Further info on removing the insulation covering the grid lines:
I've found repair kits that seem to have light grit sandpaper included, and other kits that make no mentipon of removing the insulation.
I don't know which will work better, but I can't see how a kit would work if the insulation isn't removed.
