I tried to find the original thread about this but couldn't find it. I'm having some issues with my key/ignition/steering column. The car will start and run but the key seems to slip backwards or something into the off position just enough to shut it down. I figured that out because if you hold your finger on the key a little bit forward while it's running, it stays running.
Well, i took the column apart some and poked around but the only thing i've found that looks suspicious is a red/green wire that's been spliced into for my electric fan. I'm not sure but i think that might be the off/run wire or whatever. Something is going on with the off/run, because it fires RIGHT over with a turn of the key but it immediately dies...doesn't run at all, just fires over and shuts down. I removed the splice and wired this wire back together but it changed nothing.
So now i'm at a loss. I know a lot about this car but not a whole lot about the electrical aspect because i've never had to screw with it so i'm F'in lost
