5.0 Fuel press regulator
stangman16
640
San Antonio, TX
How hard is it to change out the Fuel Pressure regulator on a stock 5.0 89-93 Mustang? Do I need to take off the fuel rails in order to do so?
I went through the EFI no-start checklist, and fuel does not come out through the opening of the vacuum port on the regulator when 'on' and even while cranking - so I'm guessing it's shot (looks old anyhow & the pump is working).
Are there any special tools required to remove it?
Thank you!
I just changed mine. There are three allen bolts that you can access from the bottom of the fuel rail. Take those out and drop in the new one. Really easy. Do you have a fuel pressure guage? If not you may want to get your hands on one. I think Jeg's sells them for $35. If you need a new regulator I have one the I replaced for an adjustable one you can have for the cost of shipping.
Darreld
It really helps if you take off the upper intake. I tried to do it without taking off the upper plenum, and I couldn't get the last bolt. That's on the to do list! Other than that...it's pretty darn simple.
You can put one on the fuel rail I believe...there is a port on it, if I'm not mistaken. The aftermarket fuel pressure regulator has a port on itself for a gauge. If you have the cash, it's a great supporting mod for later things (HCI/blower/nitrous/turbo).
Is there one that would work with the stock fuel rail and pressure regulator that you can recommend?
NOS makes an adapter for FPRs- that's what I used. Put plumber's tape around it. (teflon)
Oh yeah, you'll have to take out the shraeder valve fitting. There's a tool for that.
The auto parts stores have gotten better about renting/loaning test tools. I recommend that you check and see if there is a fuel pressure test gauge available for loan/rent. I spent $35 and bought one because it looked like a good tool to own.
The cheap & dirty way is to use a tire pressure gauge, but the acccuracy may be a bit off. Watch out for the squirting fuel if you try the tire gauge...
j, would dropping a fuel pressure guage offset the calibration of the guage? the reason i ask is most parts stores(franchise) have a bunch of kids who really dont care about there jobs throwing tools around, i was going to rent a torque wrench from a. zone and the guy dropped it from about 4.5 feet up, picked it up handed it to me and said dont worry there tough. i dont trust auto parts stores tools that require precise measurements. just my 2, but if droping a guage does not do the same as dropping a torque wrench themn it would be fine i guess.:flag:
