Ok well I decieded to replace the crankcase breather on my car just now and well after fighting and prying I replaced it. Well when I started my car I hear a whistleing. Then it starts idling funny. Then it started to stall while idling and when you give it gas it seems to be fine, as long as its revved. I know its a vacuum leak, Just dont know from where it could possible be. I checked the hoses for the pcv valve and they seem fine, and the tee there for the hose that runs to the pcv to the manifold or something and to somewhere under the manifold is good. Any other suggestions?
) are really prone to vulcanizing. I wouldn't worry about the fitting on the intake - you'd have to really pry on it to screw it up. If you did, it should be easily fixable.
