Installed ASP underdrive pullies today
UPS delivered my ASP aluminum underdrive pullies today and since in was nice out (65*) I decided to install them today. The install didn't take to long, probably because I didn't install the alternator pulley because I didn't want charging issues. After putting them on I took the car out a to nice backroad that could almost be used as a sanctioned road race course to see if they made a difference, all I can say is wow they woke my car up alot. The car revs up stronger and smoother and has a more powerful feel to it. No regrets on this mod:D
when the car warms up you will notice it to slowly go down...also watch out in the summer they could cause overheating problems too, that is why I am putting my stock ones back on....but they do really wake up the car.
When you have the A/C On too it will drain it a little faster. Just make sure to watch out for it. If your radio cuts off, give it some gas right away so it dosent die. I had to do that alot with mine.
i know i soooo regret doing underdrives on my 93 it is bad in that car..and as mentioned as you drive it goes lower ...and there is no charging at idle....totally sucks...
however the alternator in a 93 is much lower amp rating then what was installed in a 94 i believe the 93 had a 65a..? and 94 was a 100a...? maybe im wrong...i would like to do underdrives on the 94 but i see a lot of people having issues so it scares me and i feel its crapy to buy a pulley kit and not use all the pullies so i might stick with stock pullies until i get some solid evidence of the charging issues
You can make a significant difference on the amount of juice your
alt cranks out with just a couple of hundred rpm.
On a stocker or bolt on Stang ................
Peeps have no need for a higher idle
hence
You see them cry about ud pullies
H/C/I combos usually need an idle rpm of 800 to 900 rpm which
can give that advantage of extra juice from the alt
I got em on my 95 :nice: with no problems ;)
Free rwtq :D ALL across the ENTIRE power band :banana:
The kinda deal :eek: .......... I just ain't gonna pass up :nono:
Grady
Install the alternator pulley, you won't have any issues
hence
Grady
:nice: That's exactly why I don't have any problems. I have mine idleing at 750. It just seemed like more of a happy place and helped with some driveability. That must be the difference maker right there.
I didn't even think of that being why I don't have any problems. :bang:
Adam
That is the thing to keep in mind about our hobby.
We all got a Stang :banana:
but
Our expectations or goals for it
determines
Our application of how we use it
thus
It is not ALWAYS a black or white answer we can give others
when they ask for help, advise, or info.
I have often thought .......
Ya'll get tired of me seeming to focus
a lot of my replies around that phrase ........... it depends upon :shrug:
anyway .......
You gotta admit it :D
If you pay attention ;)
You can learn good stuff on these boards :nice:
I know I learn from you guys every day :hail2:
Wish I had an internet when I got started in this hobby :rlaugh:
Grady
