- Feb 13, 2006
- 97
- 0
- 0
I've never gotten one to take more than 2 1/2 quarts, how did you get 3 3/4 quarts in there? Friction modifier is an additive that allow the clutches in the differential to function properly and noise free.
yeah i found it after a little more detailed inspectionit was completely covered with dirt. i had to scrub the differential to find it. What is friction modifyer? Also my differential would only take about 3 and 3/4 quarts of fluid. the guy at pepboys told me 5 quarts to fill it
I think it's more like 3.75 pints, no?
As stated, FM lowers the coefficient of friction in the friction materials (clutches and plates), which keeps the friction material from biting 'too hard' during times when wheel speeds are differentiated. Some synthetic fluids come with FM already added. Otherwise, Get the FM from the dealership - it's under 5 bucks.
Good luck.
I have an Aluminum Cover and it has a drain and fill plug on it.
2 1/2 quarts is more than enough, and you DO NOT want to overfill it.2 quarts and the 4 oz. bottle of friction modifier is just about enough to fill the differential case and get it dripping out of the fill plug (a little more if the car is jacked up level). I don't know how you got 3 3/4 quarts in there through the fill plug (unless you have a non-stock differential cover).2 1/2 quarts is more than enough, and you DO NOT want to overfill it.
An alternative way to fill the differential is to remove the vent on top of the right axle tube, and fill through the hole with a hand pump, but you need to put in a measured amount so you don't overfill.
