Differential Oil Change
The fill plug in on the 'front' of the differential. If you look at the drivers side front of it, you will see some webbing and there's a square-fitting plug (the plug uses a 3/8" ratchet to loosen it) you remove.
Wear some gloves and protect youself when you break that plug loose. More than one stanger on here has cut themselves pretty badly when that fitting breaks loose. I use an impact fist for stuff like that (I hit the ratchet with my fist to break the thing loose).
Good luck.
yeah i found it after a little more detailed inspection :bang: it was completely covered with dirt. i had to scrub the differential to find it. What is friction modifyer? Also my differential would only take about 3 and 3/4 quarts of fluid. the guy at pepboys told me 5 quarts to fill it :shrug:
I think it's more like 3.75 pints, no?
As stated, FM lowers the coefficient of friction in the friction materials (clutches and plates), which keeps the friction material from biting 'too hard' during times when wheel speeds are differentiated. Some synthetic fluids come with FM already added. Otherwise, Get the FM from the dealership - it's under 5 bucks.
Good luck.
Good luck.
yeah my bad it was 3.? liters, lol
2 quarts and the 4 oz. bottle of friction modifier is just about enough to fill the differential case and get it dripping out of the fill plug (a little more if the car is jacked up level). I don't know how you got 3 3/4 quarts in there through the fill plug (unless you have a non-stock differential cover).:shrug: 2 1/2 quarts is more than enough, and you DO NOT want to overfill it.
An alternative way to fill the differential is to remove the vent on top of the right axle tube, and fill through the hole with a hand pump, but you need to put in a measured amount so you don't overfill.
i bought a 1 gallon container of oil and used about 3/4 of it untill it started weeping out of the fill hole. i'm not driving the car yet so i will check it this week. i'm going to drain a little and put the friction modifyer in before i take it out. thanks guys. :SNSign:
