stevesLX Member Nov 12, 2006 373 0 16 cincinnati Feb 15, 2007 #1 Feb 15, 2007 #1 Does anyone know how tight thr crankshaft pully bolt need to be torqued down to?
TRWXXA Member Jan 18, 2003 190 1 19 RIGHT BEHIND YOU!!!... Made you look. Feb 15, 2007 #2 Feb 15, 2007 #2 stevesLX said: Does anyone know how tight thr crankshaft pully bolt need to be torqued down to? Click to expand... If you mean the large bolt that holds the vibration damper to the crankshaft, it's 70 to 90 ft/lbs. If you mean the 4 bolts that hold the pulley to the vibration damper, it's 35 to 50 ft/lbs.
