Which model of Optima are you guys running in your foxes? Are there different sizes of red top? Clearence issues?
GM vehicles). My truck is side post.It says the 34/78 is identical to the 34 & 34R except the 34 and 34R are only top post. I'd say get the 34/78 just in case you do want to use it in a vehicle that requires a side post battery (like many - if not allGM vehicles). My truck is side post.
I always thought red tops were for cars and yellow tops were more for boats![]()
http://www.optimabatteries.com/publ.../product_info/commercial/technical_specs.html
Thanks for the info. I think I am going to still get the Optima though. I can always throw a trickle charger on it when not used. AND yes, my car sits more than it is driven for sure so that was good info.
I had to rig a piece of metal to get my red top to securely bolt down using my factory tray, other than that I love mine
You should give Optima a call and have them send you a Group 34/78 Hold Down Adapter. It's a plastic wedge block that snaps into the base of the battery and gives the battery hold down a place to clamp down on. They used to send them out free of charge.
http://www.optimabatteries.com/publ...uct_info/technology/hold_down_and_height.html
If you have a big wattage stereo, you want to go with the yellow top. If you NEED the extra cranking power go with the redtop, but overall the yellow top is the better battery, as it is a deep cycle and can be drained to nothing and recharged many times without effecting the battery.
