Which Optima Battery???
I TOLD YOU!!! :p
Just kidding.
OPTIMA RedTop Benefits
* Lasts up to 2 times longer than other batteries.
* More power in the initial 1, 3, 5, and 10 seconds of the starting process than comparably rated conventional lead acid batteries.
* Constant performance quality keeping your battery running at the same level even as it's being discharged.
* Ideal for seasonal use, fully charged, it can sit unused for up to 12 months at room temperature (or below) and still start a car.
* 15 times more resistant to vibration than other batteries.
* Nonspillable and can mount in almost any position.
OPTIMA YellowTop Benefits
* Dual Purpose starting and deep cycling.
Now for RED TOPs, here is a link to the specs on each model # of them:
http://www.optimabatteries.com/publ..._info/automotive/starter/technical_specs.html
I've had a red top for a couple years and love it. I got mine for around $110-120 at pep boys. I took a ruler and measured to make sure it would fit, but you shouldn't have to do that because I'm going to tell you what size mine is:
Mine is an Optima Red Top Model: 34/78, which is a top and side post battery, which you may or may not desire.
Check out this link: http://www.optimabatteries.com/publ..._info/automotive/starter/technical_specs.html
It says the 34/78 is identical to the 34 & 34R except the 34 and 34R are only top post. I'd say get the 34/78 just in case you do want to use it in a vehicle that requires a side post battery (like many - if not all:shrug: GM vehicles). My truck is side post.
You see Dave, there are different models of red. If you knew anything, I wouldn't have to post this thread. :p
I bought the grand-daddy of them all…the optima yellow top commercial! (note the weight!) :D http://www.optimabatteries.com/publ.../product_info/commercial/technical_specs.html
I was having hot start issues and decided to get a battery that was capable of starting an excavator. :nice:
Seriously though, with the battery already being re-located to the trunk I decided to get something that I could run my stereo off of….or electric fan in between 1/4 runs. I happened to have a friend that worked at Johnson Controls (owns optima) and got the battery for $100 shipped! :eek:
I had a discussion with Optima not too long ago about this very issue. In my situation (I'm sure like yours) my car sits a majority of the time not being driven especially during the winter. My father had a red top in his restored mopar and had to have it replaced 3 times by optima (all w/in 1 year). Optima clearly told me that a red top should not be used unless it is a daily driver or you have a battery tender on it when not driven. They suggested I go with the blue top deep cycle for a car that is only driven a few months out of the year and sits the rest of the time. Hope this helps and you might want to give Optima a call to discuss too:
Toll Free: 888-8OPTIMA (888-867-8462)
Phone: 303-340-7440
Thanks for the info. I think I am going to still get the Optima though. I can always throw a trickle charger on it when not used. AND yes, my car sits more than it is driven for sure so that was good info.
You just may want to check out the Optima blue top battery .. I think I'll probably go with that one when the time comes. BTW - the winter project looks outstanding.
\/ FTW~!
My cars been Stored for 3 months in the Cold and it fires right up with out hesitation everytime and in Michigan its Been as low as -14 here at most nights and Still Holds a Vary Strong charge... also with the redtop i did not have any clearance problems at all..
If you have a big wattage stereo, you want to go with the yellow top. If you NEED the extra cranking power go with the redtop, but overall the yellow top is the better battery, as it is a deep cycle and can be drained to nothing and recharged many times without effecting the battery.
I believe Yellow Top is for Cars that sit alot and ones that draw lots of Power, and the Red Top is more for a DD, I dont even think you could use a Blue Top in a Car as it is set up for Marine use. If you go to Optimas Web Site and enter a Fox Stang it says that they dont have a size that fits, whats up with that?
