I have an '02 GT.
ok let's see.... i had tranny work done then oil started leaking out which looked to be the rear main seal. But then it started blowing oil all down the whole passenger side of the undercarriage, there was a grinding metal on metal sound and it sounded like it came from the tranny, I stopped popped the hood and smoke poured from underneath it. I drove it a little ways and pushed the gas about half throttle and it started to bog and now it turns over but no combustion no starting period but pulleys do spin. I looked under the hood and there was oil sitting under the intake. When I looked at the oil filler cap it was white and smelled like gas. Before it died the motor ran too strong and didn't smoke so I don't think it's the headgaskets. Any Advice?? Thanks
and if it slipped timing chain then like some have stated already you'll most likely have bent valves and possibly damaged pistons too.
