351w Swap Front Bracketry!
OK, I'm to the point where i'm trying to round up all my front brackets that i will need for the 408 stroker. The pulleys i will be running are: Crank, Water Pump, Power Steering, and Alternator. I have a diagram of the belt routing. I really don't know what all i need. Do i need the tensioner? I see that when you remove your AC compressor that you need to move you PS Pump into its place, does this require different brackets, or do you just replace it with a idler pulley??? I know Ford Motor sports makes the 351w swap bracket for the power steering pump. http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=1400
Can someone please help me out, so many different possible ways....
I have the same set up on my 408. I used the stock alternator bracket/tensioner and I bought the powersteering bracket off a local guy. I bought that ford racing bracket ages ago thinking I was going to need it for my swap, but I didn't with the set up I have.
Here's some pics of my set up...
You say you bought the power steering bracket on some guy. Is it special bracket, i found a bracket that Ford Racing sells that eliminates the AC compressor and move the PS pump into its location. From what i can tell your PS pump is in the stock AC compressor location, right? Here the link to what I'm talking about.
http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=2424
Did you use a reverse flow water pump? And also did you have to do anything special to get all your pulleys aligned correctly. Thanks
-AJ
AC/PS-
This is the only stock 5.0 accessory bracket that requires modification. The original AC pump and Power Steering pump can be reused if an FRPP bracket is used. If using Power Steering only (without A/C), the FRPP part number is M-8511-A351. For both AC and PS applications the FRPP number is M-8511-B351.
AC/PS-
Is this bracket needed since the power steering will be getting moved up into the AC compressor's location?
-AJ
The bracket I have for my power steering pump is the aluminum piece shown in that ford racing link you provided. Yes, I'm using a reverse flow pump and I didn't have to do any modifications to anything to get the pulleys to line up properly.
