What would cause my motor to free spin all you can hear is the starter and the engine rotates but no huffing or trying to crank can anyone help me..
fuel is good fuel pump is good...injectors are pumping
when i turn the key on i hear it click but i will check it and my fuel filter do you think there is anything else it could be...
OK I was talking about the fuel pump clicking on and the engine spinning no huffing the timing chains are tight not loose at all I took the valve covers off I dont know how it could have Jumped time or even if it did but when I was driving it and gave it some gas it bogged out and started doing this...I just went and checked and its getting plenty of fuel it squirted to the top of my hood as far as spark how do i check that?
When you had the valve covers off, did you crank the engine and were the cams spinning? Any backfires when attempting to start it? I'm sticking with cam timing. If you have the covers off, bring it around to top dead center on number one cylinder and both valves should be closed. If they're not, somehow you jumped time. I've never had the chain covers off my engine. Is there a keyway on the crank pulleys that could have broke?
anyone got anymore ideas?
