Compression test
stevesLX
373
cincinnati
I was told by machine shop to perform a compression test to see if I have any bent valves. I had a pushrod that bent on me and I have since fixed all that but still have noise from valvetrain. So I contacted the machine shop and they said the easiest way to tell if you have any valves that are bent without pulling the heads is to do a compression test. So is there anything special I need to do for this compression test. Or do I do it the same way as if I was doing it to determine whether or not a car has blown rings. I know the machinists mentioned something about if I had any bent valves that I will not have hardly any compression on that particular one or something to that effect. Any help would be appreciated on this.
If the engine is running and not making major noise, do a cylinder balance test.
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a
jumper wire or paper clip to put the computer into test mode. Start
the engine and let it go through the normal diagnostic tests, then
quickly press the throttle to the floor. The engine RPM should exceed
2500 RPM's for a brief second. The engine RPM's will increase to about
1450-1600 RPM and hold steady. The engine will shut off power to each
injector, one at a time. When it has sequenced through all 8 injectors,
it will flash 9 for everything OK, or the number of the failing cylinder
such as 2 for cylinder #2. Quickly pressing the throttle again up to
2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is
weak and isn’t putting out power like it should. See the Chilton’s Shop
manual for the complete test procedure
Here's the link to dump the computer codes with only a jumper wire
or paper clip and the check engine light, or test light or voltmeter.
I’ve used it for years, and it works great.
attachment.php
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections,
see http://www.actron.com/product_detail.php?pid=16153 for what a
typical hand scanner looks like. Normal retail price is about $30 or so
at Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes
or beeps.. Cost is $33.
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder
balance test. Low compression on one of these cylinders rules out the
injectors as being the most likely cause of the problem. Look at cylinders
that fail the cylinder balance test but have good compression. These
cylinders either have a bad injector, bad spark plug or spark plug wire.
Move the wire and then the spark plug to another cylinder and run the
cylinder balance test again. If it follows the moved wire or spark plug,
you have found the problem. If the same cylinder fails the test again,
the injector is bad. If different cylinders fail the cylinder balance test,
you have ignition problems or wiring problems in the 10 pin black &
white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark
plug hole. The other type leaks too much to get an accurate reading.
Your local auto parts store may have a compression tester to rent.
If you do mechanic work on your own car on a regular basis, it would
be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the
throttle wide open, crank the engine until it the gage reading stops
increasing. On a cold engine, it will be hard to tell what's good &
what's not. Some of the recent posts have numbers ranging from
140-170 psi. If the compression is low, squirt some oil in the cylinder
and do it again – if it comes up, the rings are worn. There should be
no more than 10% difference between cylinders. Use a blow down
leak test (puts compressed air inside cylinders) on cylinders that
have more than 10% difference.
See the link in my sig for details on how to build your own blow down type compression tester.
o.k. on this cylinder balance test when you say use a jumper wire or paper clip I assume you are saying to do like what you would do to pull codes. My car is a 89LX and the check engine light is not wired up so I have a volt meter to use instead but my car will not pull codes while it is running. Neither myself or the dealer have been able to get 1 code out of this car while its running.
I know for a fact that my noise is valvetrain. I just want to make sure if I have a bent valve that by doing just a plain jane compression test will work. I have heard rumors that in order to find a bennt valve by doing a compression test you need to also take all you rockers off the heads so all your valves are shut and do the actual test. That seems like quite a bit of work if not neccessary.
if u take all ur rockers then ur valves wont open to suck in the air, close, compress, and build up the compression to show up on the gauge....basically that makes no sense :shrug: .......One way I heard by a good mechanic is take off your rockers and lay a straight edge across all the tops of the valve stems, they should all be level together....if one's bent, it should be lower than the others.....or also do a leakdown test, if a valves bent and isnt sealing right, air will leak past one of the valves, air will come out of the intake or exhaust. Also if its bad enough and truly is a bent valve which I wouldnt be surprised if it was something else, you can hook up a vacuum gauge to the intake vacuum and youll see a flicker in the needle.
