Fuel injectors how to test
stevesLX
373
cincinnati
I think I may have some injectors that are bleeding down or getting stuck open. Everytime I shut the car off the fuel pressure drops off to zero quite quickly. Its like it doesn't hold pressure after you shut it off and I am getting gas in my oil. Is there anyway to test the injectors to find out or is it just go out and spend the money to replace them. These are 24 # injectors. 302 motor. I also have a AFPR and I checked the vacum line on the AFPR and it is dry. I also started bthe car and used a pair of vice grips and tried to crimp off the fuel return line and the pressure stayed the same on the guage. I only had it crimped off for a minute. Not sure if I nedd to leave it crimped off longer or not. But I was told if I crimp it off and the pressure doesn't rise that I have a leak somewhere. Dont no if thats true or not or if the pressure should rise right away. Any help on this would be appreciated.:bang:
Fuel pressure OK, the injectors are not firing, OR one or more injectors stuck
open
Do a cylinder balance test: Warm the car's engine up to normal operating
temperature. With the Engine Off, Key OFF, use a jumper wire or paper clip to
put the computer into test mode. Start the engine and let it go through the
normal diagnostic tests, then quickly press the throttle to the floor. The
engine RPM should exceed 2500 RPM's for a brief second. The engine will shut
off power to each injector, one at a time. When it has sequenced through all
8 injectors, it will flash 99 or the number of the failing cylinder such as 22 for
cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause
the test to re-run with smaller qualifying figures. Do it a third time, and if the
same cylinder shows up, the cylinder is weak and isn’t putting out power like
it should. See the Chilton’s Shop manual for the complete test procedure
The red wire on each injector is powered up whenever the ignition switch is
in the Run position. The computer provides a ground to complete the circuit
and fire the injector. The injector must have a ground to squirt fuel on
command. A short to ground in the injector return wiring can cause one or
more injectors to be continually open or triggered
A.) A Noid light available from Autozone, is one way to test
the injector wiring. If the light stays on constantly, either the wiring has a
short to ground or the computer has failed
B.) I like to use an old injector with compressed air applied to the
injector where the fuel rail would normally connect. I hook the whole thing
up, apply compressed air to the injector and stick it in a paper cup of soapy
water. When the engine cranks with the ignition switch on, if the injector
fires, it makes bubbles An injector stuck open will release a continual stream
of bubbles. Cheap if you have the stuff laying around, and works good too.
The same trick works great to find leaking injectors too.​
The wiring for the injectors may have some bare spots in it causing the
injector to computer control wire to ground out. This would cause the
injector to remain on anytime the key was in the Run position. Remove the
injector wiring connectors from the injector. Note that each injector has one
red wire for power and a non red wire (wire some color other than red) for
computer controlled ground. With the key off, disconnect the computer
connector from the computer. Use an Ohmmeter between the non red wire
and ground. You should see more than 100000 (100K) ohms resistance.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host) for help wiring http://www.veryuseful.com/mustang/tech/engine/
Using the above diagram, check the resistance between the injector and the
computer. Clean and check the 10 pin connectors since they are a potential
trouble source. Any resistance greater than 1 ohm between the injector to
computer wire and the matching pin on the computer connector is a problem.
See http://fordfuelinjection.com/?p=6 for more help
Is this the same as the set up on 1992 F-150 pickups with 302's?
Per the code retrieval sites I've read, yes. But the newest F150 I've driven was an '80 with a 302 of a different configuration. :p
The trucks sites should be more specific.
Good luck.
I'll try it again but when i had my code reader in to try to perform the cylinder balance test in the truck the test would not initiate. Perhaps i didn't get it above 2500 rpm. I did map the throttle but only for a split second. I'll try again 2morrow.
I used a noid light and tested the harness on my injectors and every single one was the same. A constant blinking light at idle and if I gave it gas. So now I assume that its not my injectors thats causing me to have gas in my oil. And my pressure bleeding off right after I shut the car off. So whats next and how do I per form other tests to figure this out?
Jrichker will have some neato things for you to do with compressed air, soapy bubbles and ten college girls (the last item isnt part of the test but adds to the fun factor). :D
I'd put a FP gauge on the schrader valve, start the car and let it run. Then shut the car off and watch the pressure drop per time. If it drops quickly, do the same test but just as the key is turned off, place fuel-line-criming-pliers on the return line. Now watch pressure drop. If just as quick as before, that suggests an injector leak or weak pump check-valve. But if pressure bleeds off more slowly, the drop came from the FPR.
None of this is nearly as effective as testing the injectors directly, but it can give an idea and save yanking the injectors.
Good luck.
EDIT: In regard to your injector question: All the noid light does is tell you that the electrical ingredients to make an injector fire are reaching the injector. They do nothing to tell you if the injectors actually function, are clogged, are squirting or leak.
Basically if i read the write up from JR properly all you have done is rulled out that an injector is always staying open. You have done a test to prove that your injectors are pulsing. As far as the gas in your oil goes it has to be coming from the injectors because thats where the fuel enters the engine from. Perhaps one or more is actually bleeding down. I guess the next thing to do is find out which is bleeding. For that i'm not sure how you do it.
oil seperator
I am going to go to a hardware store and get a seperator for my oil that keeps getting in my manifold. Does anyone know what parts I need to pick up and exactly how this will hook up in the car?
Oil separator (a search will reveal a lot of threads):
Most separators have 1/4" NPT fittings. I used two plastic fittings that had a 90* bend in them. They were 1/4" NPT thread with a 3/8" barb fitting. I used 3/8" hydraulic line to and from the separator.
Good luck.
It was in the eariler post I made...
"B.) I like to use an old injector with compressed air applied to the
The same trick works great to find leaking injectors too."
Well I have a air compressor and I have cups and soapy water. So I assume that I will have to pull my injectors off and test each one. Now since I am going to be putting my injectors in soapy water is there anything I need to do before installing them back in the car if they are still good. Gas soap and water dont mix well. Also I will need to get new O rings for these is there anything special about these since they are 24# or can I just go to a autozone and ask for Orings for fuel injectors.
Blow them dry with the compressed air when you are done and all will be good. Since the soapy water is on the outside, it comes off easily.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit.. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
The pintle caps fit either injectors with a pin sticking out the injector end or 4 with more tiny holes in the injector end
O.K. just thinking about this some more and I want to make sure I am clear on how to do this test. I need to pull one of my injectors off the fuel rail and leave the harness hooked up to it and hook a air compressor up to it put it in a cup of soapy water and start the car. Now what exactly will I need to put on the end of my air hose to fit into the injector and I assume I will need a spare injector to go where I pulled the one out other wise when I start the car gas is going to spray out all over the place?
