Tell me about the CS....
Radman
113
Texas
I have a 2007 GT/CS While I enjoy the 18"wheels, parchment interior, and blackout stripe, I am not that to enamored with the hood scoop.:(
The hood scoop is bolted on. Is there a big hole under that baby or can I just unbolt it and move on?:shrug:
Also, the side scoops are 2x taped on right? Will I hurt anything just yanking them off?
Rad
i believe that the hood scoop will have holes where it is bolted down. the side scoops are more than likely douled sided taped on to the quarters.
i have never looked at the car in person so i cant tell you 100%.
I have an 06 GT and I added the hood scoop and the side scoops. Each come with instructions and templates for drilling:nice: On the side scoops you have 2 clips that snap into the side of the quarter panel as well as double sided tape. The hood scoop I believe has 8 clips and 4 bolts.
Perhaps you needed to just buy a Regular Mustang GT then added the Front and Rear CS pieces. The CS has a certain style that you like or dislike but never buy something just to take items off you don't like, work the other way around.
dly 07 Black GT/CS
I don't think so. I have heard that the Shaker system will not cover the holes.
-Jason
Well it'd be pretty easy to find out. you could drop the hood liner and see where the bolts and holes are. I would be surprised if they didn't because when I saw the scoope at the auto show recently it didn't seem any larger than a shaker, especially when the trim ring is taken into account. Could certainly be wrong though. May be worth an E-mail to CDC to find out.
You don't even need to drop the hood liner...just open the hood. There are seven bolts, coming right through the liner. My scoop looks a lot bigger than the shaker scoop, so I don't believe getting the shaker will do you much good...the holes would still need to be filled.
