Well I tested all the injectors last night with the air and soapy water and they are all good none are leaking. So whats next. Also what is a shrader valve? And just to let you know I have been up in the engine compartment when the car has been shut off or stalls out and the fuel pressure guage drops to 0 within a 1 1/2 seconds.
The schrader vavle is located in the fuel injection pressure feed line just behind the alternator.
It is for the fuel pressure test gauge. If you have an under hood or passenger comparment
gauge, it may have been removed to provide a pressure source for the gauge.
fuel pump pressure test
Disconnect the larger of the two fuel lines up by the Schrader valve. It is the return line and
does not have the Schrader valve on it. Find a piece of rubber fuel hose and clamp it on
the return line coming from the regulator. Stick a bolt in the other end of the hose and
make sure that all your connections are tight and leak proof as possible. When this
powers up, you don't want fuel squirting everywhere. Hook up the fuel pressure test gauge.
Turn the ignition switch on and watch for leaks. You may want to use a helper inside the
car to cut the switch off quickly if you have a leak. To trick the fuel pump into running, find the ECC
test connector and jump the connector in the Upper RH corner to ground.
Caution!!! You have blocked the return line for the fuel pump! Pressure will
rise very quickly past safe levels with a good pump
If the pressure goes up
past 55 PSI, the pump is good and the fuel pressure regulator is bad. If the fuel pressure does
not hit 55PSI or more in a few seconds, the pump is bad or you have electrical problems.
If the pressure drops more than 15 PSI within 60 seonds, the check valve in the pump is bad.
If the pressure holds and does not drop off, then the fuel pressure regulator is suspect to
be the cause of your pressure drop off.
