dyno results
bill302
2,131
alabama,gadsden
well here they are n/a and 125 shot of nitrous what do ya'll think.
nice numbers bud
i know every car is different, but your numbers makes me feel good. i have pretty much the exact mods you do ( n/a ) minus the aluminum d/s. so my car -should- make about the same numbers :)
was the 13.44 run n/a?
Looks right on... is there any way you could get the actual numbers from the pull? First off, Grady wants to make a chart, and secondly, when the number scales are very different from Trq and Hp my eyes start to cross and I have a tough time with it.
Adam
Adam
the red results are the first run N/A and the blue is the last N/A run which has a approx 10 hrs. pwr. gain we did this first then run a 125 shot nitrous run and the first run on nitrous looked good for my setup and that is where we stopped the tuner said he can't get much better than the above nitrous results..also on the last N/A results the fuel pressure was dropped to 38 psi. and timing was set at 15*...for nitrous run he simply dropped timing to 10*...
and here are the rssults of the best N/A result (red) compared to the nitrous run (blue)....
Nice, thanks. I think your car is running well because those are pretty much dead on. A new intake manifold will make a world of difference.
Adam
i'm looking at buying and installing a 94-95 cobra upper and lower intake will this intake work with the maf,injectors and cai i have installed now and also give me your opinions is this the best route i can take at this point....if not give me an intake brand ect. to look for. thanks.
