there is no compression,not good,do a compression check with guage.,but it sounds like valve train related,whether cam timing slipped some how, and/or you had ptv contact and bent valves.you have mechanical issues
Ok i have spark and i have fuel and timing is good. Cam sensor is good and UDP's are fine. I bought a new ECU and Alternator and took it to the ford dealer around here and the asshat charged me 200 dollars to change out my new crank sensor and didnt fix it. you can hear compression through the H-Pipe any ideas people?
