I have a 65 Fastback with the original 289hp, but it had all the Shelby updates to the motor. These are original parts, not the repop stuff.
My question, I have been loking at 2x4 set-ups, mainly the original stuff from Ford. While looking I found a guy selling a 2x4 set-up from a company called Blue Thunder. It looks alot like the original castings, but he claims it will out perform the Ford unit.
What is your take on this:
1. Keep the Shelby 4V intake with the 715 Holley
2. Factory Ford 2x4 set-up
3. Go aftermarket with the Blue Thunder, Edelbrock etc.
Please only reply's from people in the know with this vintage engine parts.
Thanks
Thanks
The only issue is the air cleaner one though. I don't run them. I took my engine apart at 15K miles after the rebuild and the Weber install and there was nothing that looked any different inside that a normal engine. I simply changed the oil every 1000-1500 miles and avoided dusty construction areas. If I happened across one I would cut the engine and coast through and fire it up on the other side of the mess. I used to drive the car almost everyday depending on mood. In Texas the coldest day created no problem with cold starts for me so I cannot comment on that. Once you learn how to tune them they are quite easy to maintain. I used to check the carb sync all the time and it got to the point where I could touch it up in under 5 minutes if need be.
