Help with engine codes
Upon checking my codes with the KOEO, I got a 61 and 67.
I've replaced the ECT sensor and checked the connections. Still throwing the code. I checked the wires for any opens, none.
I recently did an AOD->T-5 swap and did NOT modify the wiring with the exception of plugging in the NSS and clutch pedal switch. Would this have anything to do with an ECT code popping up?
Code 61 - Engine Coolant Temperature (ECT) sensor is or was too low. Failed sensor or bad wiring for the ECT.
Note that that if the outside air temp is below 50 degrees F that the test for the
ECT can be in error.
Check the resistance of the black/white wire to battery ground. If it is less than 1 ohm, it is good. If
it is more than 1 ohm, the black/white wire has bad connections or a broken wire. Always take
resistance measurements with the circuit powered off. Make sure that you do not touch the metal
probe tips when you you’re your measurements. If you do, your readings will be off. Check the
resistance of the Lt green/yellow wire at the sensor connector and Pin 7 on the computer. It should
be less than 1 ohm. If it is more than 1 ohm, the Lt green/yellow wire has bad connections or a
broken wire.
If those tests pass, remove the passenger side kick panel. Disconnect the computer connector and
disconnect the sensor from the wiring connector. Measure the resistance between the Lt
green/yellow wire at the sensor connector and ground. You should see 1 meg ohm or an infinite
open circuit. Less than 1 meg ohm means you have some bad wiring, or the Lt green/yellow wire is
shorted to ground.
The ECT sensor has absolutely nothing to do with the temperature gauge. They are
different animals. The ECT sensor is normally located it the RH front of the engine in
the water feed tubes for the heater.
The ACT & ECT have the same thermistor, so the table values are the same
ACT & ECT test data:
Use Pin 46 on the computer for ground for both ECT & ACT to get most accurate
readings.
Pin 7 on the computer - ECT signal in. at 176 degrees F it should be .80 volts
Voltages may be measured across the ECT/ACT by probing the connector from
the rear. A pair of safety pins may be helpful in doing this. Use care in doing it
so that you don't damage the wiring or connector.
Here's the table :
68 degrees F = 3.02 v
86 degrees F = 2.62 v
104 degrees F = 2.16 v
122 degrees F = 1.72 v
140 degrees F = 1.35 v
158 degrees F = 1.04 v
176 degrees F = .80 v
194 degrees F = .61
Note that all resistance tests must be done with power off. Measuring resistance
with a circuit powered on will give false readings and possibly damage the meter.
Ohms measures at the computer with the computer disconnected, or at the sensor
with the sensor disconnected.
50 degrees F = 58.75 K ohms
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
104 degrees F = 16.15 K ohms
122 degrees F = 10.97 K ohms
140 degrees F = 7.60 K ohms
158 degrees F = 5.37 K ohms
176 degrees F = 3.84 K ohms
194 degrees F = 2.80 K ohms
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
Code 67 - clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On position
when codes where dumped. Possible neutral safety switch or wiring problem. This code may
prevent you from running the Key On Engine On tests. You can generally ignore this code, since it
has no effect on engine performance.
The computer wants to make sure the A/C is off due to the added load on the engine for the engine
running tests. It also checks to see that the transmission is in Neutral and the clutch depressed (5
speed). This prevents the car from being driven while the computer is in test mode. Key On Engine
Running test mode takes the throttle control away from the driver for several tests. This could
prove hazardous if the computer was jumpered into test mode and then driven.
Okay, I checked resistance from the blk/wht wire to the batt ground I get 132 ohms. Then I checked from the 10 pin to batt ground and I get 132 ohms as well. After the 10 pin my blk/wht wire is grey/red. The grey/red wire splits 3 ways (self test connector, neutral gear switch, and to computer).
Should I focus on replacing the section of wire from the computer to where the wire splits?
Thanks a lot, I really appreciate the help.
Before replacing any wire, measure between pin 46 on the computer and pin 40 or 60. You should see less than 1.5 ohms.
The 40 & 60 pins are the main computer ground. I have seen the connection inside the computer between pins 46, 40 and 60 go bad.
If the above test passes, then check the resistance between the 10 pin connector and pin 46 on the computer connector.
You should see less than 1.5 ohms. More than that is a bad wire or a dirty connection.
Those readings sound werid. Short the pins of your ohmmeter together, you should see less than 1 ohm.
If you see more than 1 ohm, check the leads and the ohmmeter battery.
Shorting the leads together I get less than 1 ohm. Checking the pins
on the computer again I got 123 ohms (46-60) and 129 ohms (46-40).
That does not sound like happiness and light. More than 1.5 ohms is a sign that the foil trace on the computer
circuit board is damaged. Usually this means a replacement computer. Repair is limited to someone with
very good electronics repair experience at the component level. I haven't seen many computers fail, but
when they do, this is a common failure point.
Check all the grounds prior to replacing the computer. It won't fix your current problem, but it can
prevent it from happening again.
Here's a tech note on grounds to help you along.
1.) The main power ground is from engine block to battery: it is
the power ground for the starter & alternator.
2.) The secondary power ground is between the back of the
intake manifold and the driver's side firewall. It is often missing or
loose. It supplies ground for the alternator, A/C compressor
clutch and other electrical accessories such as the gauges.
Any car that has a 3G or high output current alternator needs
a 4 gauge ground wire running from the block to the chassis
ground where the battery pigtail ground connects.
The 3G has a 130 amp capacity, so you wire the power side
with 4 gauge wire. It stands to reason that the ground side
handles just a much current, so it needs to be 4 gauge too.
The picture shows the common ground point for the battery & alternator
Picture courtesy timewarped1972
3.) The computer has its own dedicated power ground that
comes off the ground pigtail on the battery ground wire. Due to
it's proximity to the battery, it may become corroded by acid
fumes from the battery. It is a black cylinder about 2 1/2" long
by 1" diameter with a black/lt green wire. You'll find it up next to
the starter solenoid where the wire goes into the wiring harness
4.) All the sensors have a common separate ground. This
includes the TPS, ACT, EGE, BAP, & VSS sensors.
5.) The O2 sensor heaters have their own ground (HEGO ground)
coming from the computer. This is different and separate from
the O2 sensor ground. It is an orange wire with a ring terminal
on it. It is located in the fuel injector wiring harness and comes out
under the throttle body. It gets connected to a manifold or bolt on
back of the cylinder head.
6.) The TFI module has 2 grounds: one for the foil shield around
the wires and another for the module itself. The TFI module
ground terminates inside the computer.
7.) The computer takes the shield ground for the TFI module and
runs it from pin 20 to the chassis near the computer.
8.) The computer's main power ground (the one that comes from
the battery ground wire) uses pins 40 & 60 for all the things it
controls internally.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103#volt
for help troubleshooting voltage drops across grounds
Extra grounds are like the reserve parachute for a sky diver.
If the main one fails, there is always your reserve.
The best plan is to have all the grounds meet at one central spot
and connect together there. That eliminates any voltage drops
from grounds connected at different places. A voltage drop
between the computer ground and the alternator power ground will effectively
reduce the voltage available to the computer by the amount of the drop.
I recently yanked out the A/C components and put in a 1 wire high output alternator, and have left the wiring for both the A/C and alt hanging. Could that have caused my computer to fry?
Also, there are no other wires that meet the secondary ground at either point (manifold/firewall). It's just a ribbon looking wire that goes from the manifold to the firewall. Is this right?
The OEM engine ground was either a braided wire or 10 gauge green wire that ran from the firewall
to the back of the cylinder head or intake manifold.
I recommend that an extra 4 gauge ground wire be provided when a 3G or other high current
alternator is used. That one gets bolted to the engine block and the chassis ground being pointed at
by the screwdriver.
