OK its Party time., My car was tuned by Alternative Auto, You being from Michigan May very well know Lidio and his tuning capabilities. Before I took my car there with no tune and O2 sensors it ran like crapp, choppy idle and all unstable. After Lidio's tune with an SCT chip and no O2 sensors everything is perfect. So once again, O2s on a custom SCT tune does nothing. The chip is programmed to tell the compter what to do at this point the O2 sensors have been disabled.
My opinion, your tuner is a hack, and he ripped you off. Here is why I feel this way...
Without the O2's you have lost the Adaptive Strategy. The Adaptive Strategy is what compensates for sensor variation. For example, 2 brand new ECT sensors may be slightly different. OR similarly, a sensors output will vary as it ages.
Both of these types of differences will introduce error into your 'now perfect' custom tune.
What happens when your ACT gets fouled up?
What happens when your MAF gets fouled up?
What happens as you ACT/ECT age?
All of these things will cause small variations in your tune.
Normally, the Adaptive Strategy will correct for that.
However, you will just see your custom tune start to degrade.
You may even see a difference in the tune with weather changes... Others have reported this...
Most often Open Loop tuning is easier for a tuner to figure out and get right. Look at it from the perspective of the shop performing the tune...
The more tunes he can do in a given day, the more money he makes...
If he can cut an 30 minutes off your tune time, then maybe he can squeeze in one more tune per day.
The bottom line is...
Creating a custom tune which does not utilize Adaptive is a short cut.
I seriously doubt that installing O2's will do any good for you now. Unless the tuner took another MAJOR shortcut, you will need to get the car re-tuned in order to get the car into CL.
My advise is to go back to the tuner, and ask him to do the job right.
Actually, no... I would just find another tuner...
But that is just my opinion,
jason
