What's the easiest way to get the front brakes off?
Therian
The Highlander
Waterloo, Ontario
I haven't tackled brakes before, and the last time I went to do it, my C-clamp was about 1/4in too short to fit over the caliper. Is there a way to get the brakes off without compressing the piston? I'm doing the cobra swap + 03 cobra A arm + struts, so everything needs to come off.
Thanks guys
I used a huge C-clamp, but it didn't take much to compress them. The other thing you can do is take a large flat screwdriver or pry bar and wedge it between the rotor and the outer part of the caliper, and wiggle it and whatnot. You don't need to move it much to take it off. As for taking the caliper off, don't bother with the torx screws that hold the caliper to the bracket, just remove the two braket bolts at the back and everything will come off as an assembly. It took me about 1 hr to take both sides apart and install the Bullet kit. Easy as pie.
Also, my rotors were really stuck to the hubs, but nothing 3 minutes with a BFH and double-fisted swings can't fix :D
How does it look with the new rims? must be badass. pictures?
Also, the two bolts I want to take off are the ones that attach the bracket to the spindle, right?
Thats correct man, I believe they were 15mm heads. They were tight, I used a 36" breaker bar to take them off lol.
Here's a couple pics, but the car was really dirty
I'm waxing the car this weekend, there will be plenty of pic-whoaring to come :rolleyes:
GOOD LUCK...
I broke 3 15mm sockets on the bolts that hold the caliper to the steering knuckle on my car. Had to take angle grinder and grind off the heads.
THEN on my 03 control arms I had to use an angle grinder to cut my arms off so I could cut the front bolts off. Of course this also meant $50 in new bolts/washers...
So good luck. Hope your car is easier. My car seems to be one of the worst on here for this type of stuff.
GOOD LUCK...
I know they're usually not cheap, but it would be wise to invest in a set of 1/2" drive impact sockets if you haven't yet. I got a full set of metric and standard ones on sale for $25 that was reg. $100. Best $25 I ever spent, seems there's almost nothing I can't unbolt with those and a huge breaker bar :rolleyes:
And if you manage to break an impact socket, then you've done something :D
I'm not sure I follow Mr Highlander, but I'm sure you know about brake caliper piston retracting tools. Much better than a C-clamp because the force is against the piston and inside of the caliper (not crushing the caliiper as a C-clamp does).
They are 10 bucks or less (USD) and well worth it IMHO.
Good luck Duncan.
P.S. when I read the title, I thought this was gonna be some topic that belonged in a car fetish forum. :D
Good luck Duncan.
hahaha...I dunno...I've always found brakes to be very sexy :p
I'll pick up the tool you mentioned next time I'm heading out to work on the car
So Duncan, did you manage to git er dunn today?
I ended up only having 25 minutes to work before I had to leave (I'm storing the car at my parents house until I can get it on the road).
I took the time to soak all of the bolts with PB blaster, and then I attempted to move one of the bolts with a 15mm wrench...no luck.
I need to get the 1/2in drive 15mm socket. I only have down to 16mm on the 1/2 drive sockets :nonono:
I'll get back at it on Saturday.
Thanks for the help guys
Make sure it is a 6pt socket.
Although, if you have a grinder it may be worth the time jsu tto grind off the head and buy new bolts. They are like $6 each I think but have the thread locker on them too..
If we're trying to get the brake caliper bolts loosened (you guys can make anything sick and twisted BTW :p ), if not mentioned, rap the wrench with a 4 pound hammer. The shocking is like an impact gun and will loosen the bolts up (but should not snap them, like lots of leverage can).
im confused about needing a clamp :scratch: i know the rear calipers need to be ratcheted in with that special tool but to get the front caliper out if the caliper wont come off the rotor i would slip a screwdriver or something between the caliper and rotor like how the rotor turns through the caliper and pry up it should pop off...if you were concerned about getting the caliper to compress now to put new pads in then i understand the c clamp :D
