Help with nitrous
stevesLX
373
cincinnati
I just got my nitrous hooked up and I have been told that I need to watch my pressure in my bottle. I was told that my pressure in my bottle should be between 950-1000 when I go to spray it. Well I turned the bottle on just before and its only at 600. The bottle is full and its been full for about 3 days now. So how do I get my pressure up to 950-1000 if that is where it really needs to be? I intended to use this tomorrow at the track. Its a Zex dry kit and I am using a 75 shot on it right now. I was told that if I spray it at anything under 950-1000 that it would spray to much and it would lean the motor out.
yes the pressure should be at 950 to 1050 psi i have mine set at 1050 and to obtain this pressure you will need a bottle heater and a pressure switch which turns the heater off when pressure reaches the set pressure you set with the switch which would be 950-1050 psi....
heres a picture of a bottle heater.
picture of a pressure switch and fitting you will need...
Well theres no way I can get those by tomorrow so I know its a tv show but I have seen guys on pinks using torchs to heat there bottles up. Can I do that or is that dangerous. And if I can do I need to leave the bottle hooked up and turned on so I can monitor the pressure guage or what?
Well yes I guess you can torch your bottle. Nitrous isn't explosive although it is a oxident. I have never torched a bottle. And I doubt I ever will. Bring your bottle inside. Store it somewhere warm. Get it in the sun when you are at the track. OH nitrous does go stale. I have nodoubt if you have had nitrous in the bottle for 3 years it has gone stale. You can know by just bleeding of some when it is disconnected. If it isn't a white spray then it has gone stale. It maybe ok.
The best thing to do is put a pressure gauge on it and put it in the sun and keep an eye on the gauge so you don't over pressure it. Then put a bottle blanket on it or wrap it in something to keep it at that temp as much as possible.
Have I seen guys torch bottles, yes. Would I do it, no. While nitrous isn't flammable I would be worried about weakening the bottle in a certain area and then the possibility of it rupturing. Not a good scene. I have seen guys torch bottles, put them on the the little coleman propane grills and turn them and all sorts of other stuff none of which I would do.
The bottle heater and pressure switch are the best way. You can dial in your pressure and it will automatically turn itself on and off to maintain it. I use the same setup on my 93.
The zex control unit works to ensure pressure problems are resolved regardless of bottle pressure..they use the "active fuel control" feature to richen up the fuel delivery to assist.
you could find a heating pad from a drugstore or med supply and wrap it around the bottle (plug in style) till it heats up and the psi is around 1k. It will work till you can get a good bottle heater, I guess a guy could go as far as buying a cheep ac->dc converter and use the heating pad all the time, ghetto but it would work if you need one asap :shrug:
LOL sounds like something my bro inlaws would do. There redneck dodge guys.
