the radio goes off, the main fan power is to the battery side of the solenoid, and yellow "switch" wire is hooked to a key on only wire i found under the hood, i think its green..anyway this all started prom night, when i got to dinner(an hour away) all was fine except the problem was still there, so after dinner i start it up cold with the fan running(it shouldent run when cold) and go to the gas station, after leaving there 30ft away i see smoke barreling from under the hood, i slam the brakes, swerve to a parking spot, kill the engine, pop the hood and jump out..there is visible smoke and strong burnt wires smell so i check everything for hot wires(hot to the touch) and found nothing unusual, so i have my g/f turn on the key and the stupid E fan controller is smoking like a SOB, so i unplugged the fuse from it, turn the key back on and it still smoked, unplug the relay on it and it STILL smokes, WTF?? so i cut the wires to the controller with my pocket knife(all this while wearing a tux in the outback steakhouse parking lot...), check for smoke and head for the highway..i made it home ok without overheating(2K RPM's at 70mph for an hour) and got my truck for the night..stupid fan controller, the first one i bought went out for no obvious reason(adjustable), the second one was preset at 185 and came on waay too late for my taste, so then i buy this one, thinking it was OK and another 60.00 down the toilet..i want to put on my clutch fan..how much HP will i lose with a clutch fan? i will miss the sound of the serpentine belt whining. Thanks for the help and i wired everything correctly, this was most definately a faulty product and not my fault
~Mark~
