Ive been burining oil under boost since i bumped my car up to 13psi, i replaced the pcv valve with the supercoupe valve, changed the rubber grommet and the filter under the valve and added a breather to the oil cap barb. I also have an oil leak in the back of the engine comming from right above the tranny/engine mating spot. It looks like the intake gasket area, but i dont know if there are oil passages over there that would be leaking (can someone confirm if there is?)...Im going to do a compression test tomorow to check the rings, but i was also thinking that maybe it was the pressure that blew out that gasket? I guess i could cap the pcv system off and check and see if the burning oil stop, and if it does then what else can i do to prevent a pressurized pcv system?
. I had a pinched hose (the one that goes from vc to intake) when I switched to an rpm 2 and sure enough when I went auto crossing a few days later I blew out the rear intake seal. I fixed the hose issue but it still leaks back there and I bet even if I take the manifold off and redo everything I am still gonna have the problem (even with the rear leaking my front is starting to leak now). I have been considering welding a nipple to my pass side VC and running a hose from there to the bottom of the upper intake (I have some extra holes there that are just plugged) to help with things. Anyone think this is a bad/good idea?
