Now why do you think this happened?
BigHairyMonkey
411
Houston (Bellaire) TX
So i wake up one day and decide to throw an old 12'' in to the back of my car. During the wiring i obviously had the battery disconected. Now i've always had cold start issues, (car wouldnt idle right unless i was on the gas for a min or two and then would run awesome as it warmed up) but after the reset the car is running poor even after warmup. I figured the computer needed some time to readjust, but after 2-3 days of daily driving im losing faith. Basically the car used to idle at a steady 800. Now it tries to find an idle at around 500-600 after its already warmed up so the whole car shakes. Also its got a slight stumble below 2k. Nothing ridiculous, but enough for me to notice, its like intermittent halts in acceleration. So i go buy a code reader (because the CEL flashed once or twice in the last couple of days) and pulled the codes. KOEO gives me code 11 and code 67.. both worthless. Havent done KOER yet, but will in the next hour and post my findings. Care to chime in :shrug:
Well what happened is when you disconcted the battery the computer lost memory and a thing called learned idle. What happened is there is a problem with your car say something like a vaccum leak and the computer relearned idle and other controls to compsentate for the problem. So when you disconcted the computer you lost its new made up controls. The reason why you probally never noticed the problem is it was a progressive problem so the computer just was compensating for it little by little and it was never a big event so the computer never made a code. You may never get the computer to completly compensate for the problem because the problem is so large. And you may have not ran the computer through a complete obd drive cycle yet. I used a vaccum leak because this is very commom the leak starts small and the computer begins compensating for the problem little by little and you never notice it. If I remember right fords have a specfic drive cycle to re learn idle it is very commn with ford for computers to loose learned idle after the computer is disconnected and sometimes there may be no problem with the car at all it just needs to relearn idle. But it is more commonly a problem. So just find the idle relearn cycle for the ford computer and preform the procedure sometimes you will luck out.
this is what i thought as well, like a vacuum leak or something that had been compensated for a long time now but rears its ugly head after clearing the computer. thanks
