Doesn't look like anyone has touched on this in a while. Looks like this was done on a 99-04 GT. I have a 98 GT. I was changing out the lights in my foglight switch and thought it would be a good time to go ahead and do something with my dash. Appearenly the 94-98 main lights are 194s.
Well, I got my Tri-Color Blue Led's from Autolumination yesterday and did the install.
I was so looking forward to that nice blue as seen in the pics, but instead was treated to half assed dimly lit gauges. I could barely see my Oil Temp and Fuel gauges. AND, the gauges were still GREEN!!
All of the LED's were installed correctly and functioning as behind the cluster, it was bright blue, but for whatever reason, the blue was not showing thru.
I had to toss my stock bulbs back in as there was just no way I could drive with the blue led's. On my speedometer, 10mph thru 40mph was completely dark.
Hope is not lost though, as I intend to figure out the correct way to make this work as switching the bulbs is a cake walk.
Thanks for the info, I will try again 2nite!
have you experienced with any of em? Tracy from autolumination just emailed me back saying the best 194's for the hvac controls are the superstars with heatsink, guess I will try those
Yup, looks like this only works with White face gauges. Here's my stock cluster with the blue tri-led's. All bulbs confirmed on and lit.
Also, in order to make installing the tri-led's a lot easier, take off the white panel exposing the board. This will give you direct access to the holes. No playing operation with the bulbs.
