2valve,3valve
Rangers68
I hear that the 2valve mustang engine is not good. is that true, and i also hear that you can make your 2valve a 3 or 4 valve engine, where can you get those parts, and how much? and how much of a difference will their be in performance? Also, if u take a 2valve and swap it out for a 4 valve, does that make it equivalent to mach 1 or a cobra engine, minus all of the extra performance parts that it already has?
By the time you swap out heads for 4V cobra heads then install 4 new cam shafts, valve covers, a whole new cam chain system, solve fitment, and retune the car/ reprogram the ECU it's cheaper to just buy a used cobra engine - and im leaving out a lot of steps. Plus it wont even be as useful as a cobra block, they are alluminum for weight and have a forged bottom end, and a helluva better intake system (which actually would be needed cuz urs would no longer bolt up to the 4V heads).
Excluding the 99 and 01 Cobras, which only have a forged crank but not rods/pistons.
03 and up are all forged.
it has alot of potential. in stock Short block form your going to be limited to about 400rwhp.. some push more and last but most dont.
If you can find a donor car for the 4V swap for cheap then it is worth it, otherwise put forged internals in the 2V and boost the crap out of it.
the 2v has plenty of potential the only thing that sucks about the 2v over the 3 or 4v is that it doesnt make as good of power with just boltons. But slap on a supercharger and it can put down some good numbers.
a little 2V with a big s/c can go past 800 HP to the wheels..... is that still no good?
my 2V has over 400 to the rear wheels right now.
+1
Im at 479RWHP on the stock bottomend...yep a 2V :D . STOCK 2Vs arent fast...but with boost they REALLY come alive. BEST bet is to do like SaleenGT2001 suggested and through some form of forced induction at the 2V. Its not worth the hassle of going 4V unless your wanting to make over 800-900RWHP....because the 2V can get you there.
There are many different options when choosing a motor for your mustang. As with everything in life it has to do with what kind of cash flow you have and what kind of power you are looking to make. 2V cars are very reliable and can safely handle just under 500HP. The block usually is not the weakest link, it is the guts inside the block. On my car it was the main bearings. 2V parts are also less expensive than the parts for a 3V or a 4V making it a good choice for a racer on a budget. I would say build what you have, and save some time and head aches. Unless of course you have some one there who knows what they are doing and can help you along.
. a good head/cam combo will go a long way, and be alot cheaper than a 4v swap, and probably perform better versus a stock 4v swap.
false. you'll barely get over 300 rwhp with heads/cams on a 2V. Buy a cobra or 3v stang and dont look back. The 2V sucks unless you want to spend a lot of money. By starting with a 4V, you'll have a much better platform to start with if you plan on doing some real mods. If you want a quick daily driver, get a 2V and just slap a KB, tune, exhaust and gears on it and call it a day. Dont waste any time/money on bolt ons. but then again, you can find a used 03 cobra for the price of what you'll pay with the right setup and supporting mods to have a safe 400+ rwhp 2V.
