70mm TB
if you have a 65mm, i would just use that one.. otherwise, i would just match the size of the intake opening.
i run a 70mm on my car (intake opening is a little larger.. probably like 73mm) and runs and drives fine.
RioRed4v touched on what I was going to point out. The EGR spacer and TB size need to match or be smaller than the opening on your intake manifold. I don't remember the exact size of the factory intake opening but I think it's right around 60mm. You'll need to enlarge the intake opening to 70mm by whatever means you have in order not to cost horsepower with your bigger TB.
absolutely NO point in jumping up a size in t/b until you have BOTH heads and intake.
FYI, I've got gt40p heads and a ported explorer intake, and a 65mm t/b is perfectly matched.
a 70 is WAY too much for a stock engine. while you won't likely loose power, it'll wack out your throttle response.
until you start packing on the mods, spend the money elsewhere.
i wish that i had saved up money for a new manifold that doesn't require a spacer than just running out and getting a tb and a spacer. look at the cobra intake, bbk ssi or others that have a "built in" spacer. in hindsight it'll make more sense than committing to the egr spacer when i'm sure that you'll eventually want to move up to a better engineered intake manifold.
as for the 65vs70mm get the 70 if you have other bigger upgrades planned, otherwise the 65 will be a better application.
i wouldnt go as far as saying ssi or cobra intakes are better than others just because they have a built in spacer.. its a nice feature, but definitely isnt something to pick an intake out by, especially when you can get egr spacers/deletes for pretty cheap.
This is what "The Mustang Shop" in Calgary, Alberta, Canada told me:
As for the throttle bodies, NA motors perform the best when using a 65MM and most forced induction motors perform best with the 70. If you choose a 70MM for your NA motor, your bottom end will suffer a bit.
