underdrive pulleys with subs?
I have udp's and also a stereo, I run a 10" soundstream 500 watt with a small soundstream amp bridged down to one ohm... I have yet to have a problem pumping the stereo with the a/c going at a light. I can't speak for everyone though.
Running a 1k watt AMP I have had no issues with Steeda UDPs even at night with the lights on, in the winter with the heat on (or summer with the AC on) all at the same time, bass maxed.
No issues, period.
And yes gains WERE noted, not SotP gains, but I could drive up certain hills with less effort.
I'm running a 1000watt 4 channel amp with another 400watt 2 channel and 2 12'in subs and i have udp's with a capacitor and i have no problem at all. No dimming at night or anything.
What's your continuous power level though on your 1000 watt amplifier?
My 800W mono-amp states "800" as max power, but only runs at 360 of continuous power at 2 ohms.
Amp manufacturers get tricky there advertising a high peak output that hardly anyone can run since the continuous power is usually most always lower than the advertised peak power.
As for the crap in the thread about "just install them but do not install one on the alt"...
The crank pulley when changed underspins ALL. The alt pulley in the UPD set is actually smaller than stock and brings the alt spin back within factory tolerences.
So that was bad advice.
